124 loom [again]
Discussion in 'Electronics' started by coupe deville, Sep 6, 2011.
  1. coupe deville
    coupe deville Active Member
    786
    Aug 21, 2008
    Car:
    93 E320 coupe sportline facelift
    sorry guys, been a lot wrote on the pesky loom recently so, altho my motor , - 104, is running well, warm up good, idle good etc, i thought i would give it a thorough inspection. I suspect a previous owner has replaced it as it looks as it should. All the connectors have been numbered in paint as if a prep for renewal apart from the twin wire that goes to the camshaft magnet [ number 3 in pic]and then loops around to 2 other connectors which i dont know what they are :dk:, [numbers 1 and 2 in pic]. These wires crumbled before my eyes as i inspected them :(. Is it feasable that the loom has been replaced but not this part , i have made temp repair and motor is still running ok
  2. grober
    grober MB Master
    27,860
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    1 person likes this.
  3. Martyn_n
    Martyn_n Active Member
    612
    Nov 27, 2010
    Leicester
    Car:
    W124 E320, ML270
    I replaced my loom last month ('95 E320) and my loom did not have the second two connectors you highlight, only the inlet cam solenoid. Having said that mine doesn't have the vacuum component you have in front of the exhaust cam so wouldn't need them.
    The wires to the camshaft solenoid were the worst affected on my loom (and they are part of the main loom) and the reason I replaced the loom. My car also had no obvious electrical problems but I am convinced it has been smoother since replacement, placebo effect no doubt.
  4. kth286
    kth286 MB Enthusiast
    2,923
    Feb 4, 2003
    Caversham Berks
    Car:
    E320 Coupe
    those extra connections (1 & 2) are the EGR wires.
    It is part of the exhaust gas recirculation emissions control but was discontiinued for later 124 E320s.
    the system can get clogged and cause a faltering engine.
  5. OP
    OP
    coupe deville
    786
    Aug 21, 2008
    Car:
    I replaced the loom today, just finished. The car is running great :), warm up and tickover spot on, engine revs seem to pick up faster and i can now rock it with the throttle again, something that it had lost. I haven't took it out of the garage yet as I'm waiting for new plugs to arrive so I haven't put the engine cover back on. I cleaned the throttle body and air valve while I was at it. One puzzle was the throttle body connector was not part of the old loom that I removed, but there is one on the new loom :confused: but it is the wrong shape and size :confused::confused:, slightly smaller, so its hanging there like a spare part :dk:
    edit, looking at the old loom gawd knows how the engine ran at all
  6. kth286
    2,923
    Feb 4, 2003
    Caversham Berks
    Car:
    E320 Coupe
    As hinted earlier, your generation loom was different in some respects to the later 104 looms.
    Have you been given the correct look (by VIN) ?
  7. OP
    OP
    coupe deville
    786
    Aug 21, 2008
    Car:
    The dealer, MB Eastbourne just asked for the reg number, the loom is exactly like the one I took off ( EGR connector etc at the front of the engine), except the new loom has a throttle body connector which is not the correct size and has nowhere to fit to as the old throttle body connector is still in situ and routes back to the ecu down the nearside wing and must connect to the ecu via one of the other plugs, although I haven't traced it back as the car is running ok. I read somewhere that there are so many variants of loom that MB standardised the replacements into 3 or 4 variants.
    The car is running great so obviously the throttle body is functioning as it should.
  8. OP
    OP
    coupe deville
    786
    Aug 21, 2008
    Car:
  9. trapperjohn
    trapperjohn MB Enthusiast
    7,316
    Nov 19, 2008
    Lancashire
    Car:
    124 300D 24V Estate
    Nice one Dave. Hope it repays you many times over.
  10. OP
    OP
    coupe deville
    786
    Aug 21, 2008
    Car:
    Hi John, thanks, Ive been looking for a Cayman S, about 5 years old, £20k ish :eek: but the old girls really flying now so she's a keeper for a year or two. Tell your mate Mr IBW that we will call and see how the old buffer is the next time we're oop north, but we've being going to Whitby a lot instead of the Lakes as SWMBO as turned into a bloody Goth :doh:
  11. trapperjohn
    7,316
    Nov 19, 2008
    Lancashire
    Car:
    124 300D 24V Estate
    Ill be seeing him tomorrow so Ill pass on your warm regards!!
Tags:
Share This Page
