chilsta
- Jul 18, 2010
- '94 S124 E300D
Hello
I've just fitted aftermarket cruise (will post more info on this when time allows).
All is working well, but it's not picking up a signal from the speed sensor.
When I bought the car it had a factory speed sensor on the back of the speedo but nothing was connected to it. I fitted a factory junction box from a donor car to the sensor & an OTG to the junction box.
I've now connected the cruise's speed signal wire to the junction box as well, but when I put the cruise system into diagnostic mode, all works well apart from the beeping/flashing LED to indicate the presence of the speed pulse. Have checked continuity between back of speedo and connector into new cruise ECU. Also tried directly connecting the cruise speed wire directly to the speed sensor.
So my questions - is there a way to test that the hall effect sensor's outputting anything? I found here that it should have around 2V when loaded with a standard cruise ECU, but doubt that this system will apply the same load. Unfortunately I don't have access to a meter with Hz reading.
I'm going to remove the sensor now and see if there's anything obviously wrong with it, but doubt this is going to get me anywhere.
Any idea if the sensor's a relatively cheap part to get from MB & could anyone help with a part number? I'm going to be in northern Germany next week and not going to have a chance to order one from the UK, so part number will save me from my lack of being able to speak the lingo.
Many thanks
Many thanks
