124 window switches removal
Discussion in 'Interior' started by brucemillar, Oct 23, 2011.
  1. brucemillar
    brucemillar MB Enthusiast
    8,663
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    Folks
    Can anybody tell me how I can remove the Center facia panel. I need to get at the window switches.
  2. GP801
    GP801 MB Enthusiast
    2,906
    Jun 18, 2010
    Sussex and Tuscany
    Car:
    2003 W209 CLK, 2005 R171 SLK in UK, 1995 S124 E280 in Italy
    I assume you do not have the centre storage box. There should be a screw under the material in the centre tray. This goes through a small bracket to hold the rear of the centre panel down. Remove this. Then remove the trim from around the gear selector. I will slide a little to the rear and then lift up. The wooden centre panel should then lift up from the rear. The window switches an be a tight fit but it will be obvious how they come out. Easiest with the cables removed first. Refitting is pretty straightforward but if you dont get it quite right it may snag the ashtray mechanism.
  3. OP
    OP
    brucemillar
    8,663
    Nov 18, 2010
    Car:
    Thank you. Very helpful.
    Bruce
Share This Page
