Hello,
Quick question, hopefully a simple one. I've just discovered a little gadget when upgrading to a Blackberry Q10, called the Blackberry Music Gateway. Basically, it lets you stream audio from your blackberry (or any Bluetooth phone really) to a 3.5mm out jack.
The CD changer in my car is very temperamental and after the last time I took it apart to remove the cartridge I haven't used it again so I was using COMAND to play CDs which is a pain when I need to use the nav.
Basically, I want to fit the Music Gateway inside the glovebox and feed it into the Aux-In port there. Problem is it needs power from a USB, I can get a 12V - USB cable no problem, I just need to know which wire I can splice into. Ideally, an ignition on feed which I can access without dismantling too much of the dash.
Looking to undertake the project next weekend, so I have all week to source/order the necessary supplies.
Thank you in advance, I suppose any dismantling advice for the dash I can rely on Karl (KillerHerz)
