12V supply for dash cam
100%Bitch
C216 CL500, R172 SLK55, R170 SLK230K, Fiat Panda, Nissan Cube & Auto Trail Comanche
Hi guys
Can anyone suggest a permanent/unswitched 12V supply for a dash cam on a c216 (or any suitable supply)?
Preferably in the fuse panel on the driver's side.
Helen
roadhog
Norfolk
'93 W124 300D x2, '89 C124 300D, '95 A124 320CE
Get yourself to Halfords and pick up one of these. Then find a suitable fuse to plug it into. Job done. :)
OP
OP
100%Bitch
100%Bitch
That's a rather good idea. :bannana:
I still need to know if anyone knows of a 12V supply which is permanently live.:dk:
How's the "chip fat burner" RH?
roadhog
Norfolk
No idea which fuse as I've never seen anything as new as your car but it wouldn't be rocket science to find one with a suitable meter. I'm around most of the week if you need a hand.
Chip burner is running sweet, very much a work in progress but that's just how I like it. :)
Edit: Those piggyback gadgets are available cheaper online from various places, I just linked Halfords for speed. They were open at the time of posting...
OP
OP
100%Bitch
100%Bitch
Thanks RH, speed is good (unless it's tablet form). :thumb:
roadhog
Norfolk
I have literally no idea what that means but judging by the look on several ladies' faces as they uttered "What? Already...?" I didn't think speed was all that good? :confused:
renault12ts
MB Club Veteran
2005 W215 CL500.
Helen, welcome back...I know a man who would know the answer but...
SG94
2020 C300DE AMG Line Premium Night Edition.
Feed to the internal light.
OP
OP
100%Bitch
100%Bitch
I'll give that a try, thanks.
markjay
MB Master
London
W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
Hi guys
Helen
On my W203, ALL of the empty fuse slots in the fuse block behind the dash on the drivers side had permanent 12V.
Using this:
I created a permanent charger for my mobile phone cradle on the dash.
Keep in mind though that the device mentioned above provides un-fused current - I added an in-line fuse.
No Biscuit
North East
CLK 220 cdi
Excellent. This thread has solved a problem for me without me having to ask. The good wife has recently purchased gps tracker units for our cars, and I was wondering how I was going to wire it in easily. Now just got to find somewhere to hide it that is relatively easy to get to(and run the cable to)
Cheers
markjay
MB Master
London
Cheers
There is quite a lot of space behind the dash, you'll see it when you remove the access panel to the fuse box. Obviously it will depend on the size and shape of your device.
Incidentally, the official location for the GPS antenna for a retrofitted COMAND on my car is under the dash, on top of the instrument cluster.
No Biscuit
North East
CLK 220 cdi
Good to know, thanks
Tracker is just a little bigger than a box of matchs
markjay
MB Master
London
Should fit nicely then.
