- Feb 8, 2007
- Location
- Portsmouth, Hampshire.
- E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
15% discount on ATF Changes at Prestige Car Service
Getting the automatic gearbox oil changed at the correct intervals is very important to maintaining the life of the gearbox. We have proven that regular changes will help the gearbox last for many miles, keep it smooth and maintain good fuel economy. We have a Viano that we look after and it has done in excess of 670,000 miles and it has had only one gearbox re-build at 500,000 miles. We have seen other Mercedes that have not had their gearbox oil changed, fail at around 70-100,000 miles.
Most gearbox oil changes are due around the 40,000 mile mark. When we replace the oil we fit a new genuine filter and sump pan gasket. The automatic transmission fluid (ATF) that we use is for Mercedes-Benz automatic transmissions.
We have done many many gearbox oil changes and put a lot of effort into making sure it is the best job possible, please see our thread on ATF Changes to see the work that goes into it.
5 speed gearbox change normally £180. £153 with discount
7 speed gearbox change normally £185. £157.25 with discount
Please call 02392 570123 or email [email protected] to book in.
PCS Team
PCS Team
