16 pin Diagnostic Flasher Codes for 1993 W124 220TE (M111 Engine )
tjamesbo
Sutton Coldfield Midlands
CLK430 ,Vito V6 sport ,Jaguar 2.5 X type ,W124's 1993 220TE , 1994 320TE ,Mastercraft X5
As I have failed MOT emissions I’ve built a Flash code Reader /blink Tester that plugs into the 16 pin diagnostic socket (Only Pins 6 ,8 and 10 have contacts ) other than 1 Ground and 16 +ve ) No codes on Pin 8 but I do have codes on Pin 6 . Looking through various fault code PDF sheets I cant find any fault code lists that list my 1993 chassis code 124 082 ? ( WDB 1240822f251114 ) Any help or guidance appreciated, as I try to work through testing all the stuff that could throw the emissions out , I thought I’d start with the onboard diagnostic code flasher
Boyd
