19"s AMGs
ibrar
Swansea-London
55 plate LWB Sprinter and soon to be C220 AMG Sport Plus
Hi guys, I was just wondering if its possible to get 19" AMGs for my '00 C250? I currently have 18"s but they seem too small. (Anybody have any other preferable choices? If so attach a pic!) Also any other upgrades I could add to me car? Here is a pic, but its not the best! 115047777646428w92eN983.jpg
OP
OP
ibrar
ibrar
Swansea-London
dammit :( stuff it, i'll just get it lowwered instead :D thanks anywho....nice valve caps?
OP
OP
ibrar
ibrar
Swansea-London
sorry malcolm but i didnt understand that website....thanks anyway :)
OP
OP
ibrar
ibrar
Swansea-London
if u put it that way, it does look simple
peppernick
Kuala Lumpur, Malaysia
E500 Sport Coupe
Some other 19" ideas for you ;)
Bobby Dazzler
MB Club Veteran
Mittel England
ML AMG-line Black Series
Not keen on mirror covers, bumpers, and handles...
but the wheels are beauties!! :cool:
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
Hi guys, I was just wondering if its possible to get 19" AMGs for my '00 C250? I currently have 18"s but they seem too small. (Anybody have any other preferable choices? If so attach a pic!) Also any other upgrades I could add to me car? Here is a pic, but its not the best! View attachment 9298
19" will look the dogs ******** but don't expect the ride to be smooooth :D
Alps
London\Essex
E55 2004 Silver(SOLD), E63 Weistec AMG(SOLD), E55 2004 Silver(SOLD), C36 AMG 1997 (SOLD)
also your car will bottom out over nearly every speedhump, and you will almost definately rub when sharp cornering or large loads!
club 202 guys normally replace shocks with koni yellow, and H&R springs to reduce this, but not eliminate!.
Rose Chap
Cambridgeshire
Lexus GS450h
Correct me if I'm wrong, but even for the very fast versions of the W202 - the C36s and C43s - AMG decided that 17" wheels were optimal.
Whilst its your car and you can obviously do what you like, don't you think 19 inch wheels are too big? Its a small Mercedes saloon, not a Range Rover!
peppernick
E500 Sport Coupe
I personally think 18"s is the largest wheel size I would want to put on the W202. 19"s will look overdone.
A nice set of 18"s and a decent drop will give you very good asthetic improvement whilst mantaining some decent ride quality.
The W202 was designed in an era where 19"s hardly ever existed for a road car.
R2D2
C350
When you have 19 inch wheels fitted to any C Class you have to have comand recoded at the same time.........................
..........................so that it remembers where your dentist is;)
NW_Merc
Banned
Over here, sometimes over there
1994 Mercedes C180 classic
My 2p worth, I agree with the other members in that my car has 17's on which is a compromise between ride quality and road holding. Bearing in mind that the bigger wheel you go to, there will be a greater tramline effect also as well as tyres rubbing on the wheel arch. I think 17's are the biggest you can go without wheelarch modification. I remember ShazAMG did modify his W202 quite a bit in order to make his 18's fit. IMHO I dont think you should go bigger, it's not always better. If you go to 19's you will have difficulty undoubtedly with roundabouts, harsh turns and the like. The Americans dont have roundabouts so only need to worry about making an occasional turn.
I think if the wheels are too big then it makes your car look like a roller skate.
Howard
MB Club Veteran
Toad Hall
CLS 500 / A 150
We have a set off BBS splitties in 19 inch that we used to run on our CLK 430 , they sit in the garage gathering dust ....
Just too big , ride is just too firm .... visit to the osteopath every week firm ...
Got 18's on it now, and the difference , just by dropping an inch is unreal ...
Don't go bigger than 18's ....
peppernick
E500 Sport Coupe
Tramlining is caused by wider tyres, not the size of the wheel. If you have very narrow tyres wrapping 19"s, the car will tramline less compared to if you had much wider tyres wrapping 17"s.
As long as you get wheels of the correct offset, tyres of the correct width and shoulder broadness, there's no reason why by going up a couple of inches will cause rubbing on the wheelarches, unless you lower the car at the same time.
whitenemesis
MB Club Veteran
I have found tramlining only occurs as the tread wears close to the wear indicators, was the same with my previous car.
Must be to do with the amount of rubber in contact with the road?
A goos reminder to change the tyres :D
