190 2.0l timing chain??
Discussion in 'Engine' started by stwat, Jun 20, 2004.
  1. stwat
    stwat MB Enthusiast
    3,175
    Jun 20, 2004
    Sheffield
    Car:
    1989 W126 300 SE
    Hello folks,
    I've just bought a 190e 2.0l. Am i right in thinking that this engine has a timeing chain instead of a belt?? ifso at what milage does it need changing??
    Thanks, Stu. :)
  2. Ian B Walker
    Ian B Walker MB Enthusiast
    7,672
    Jun 7, 2003
    Freckleton
    Car:
    300-24, saloon and coupe, E300 24 valve diesel estate
    Hi Stu and welcome to the forum, yes a 190 does have a timing chain. When I had a 190 I changed the chain at 130,000 miles or thereabouts. Depends really, if its noisy then change it, but examine the sprocket on the cam as well, look for worn teeth. Dont forget to remove the tensioner before splitting the chain otherwise its going to end in tears :crazy:
  3. OP
    OP
    stwat
    stwat MB Enthusiast
    3,175
    Jun 20, 2004
    Sheffield
    Car:
    1989 W126 300 SE
    Hi ian, thanks for the welcome and the info :) The car has only just turned 100.000 miles and has a very good service history, so should be ok for a good few miles yet :)
    Thanks, stu
  4. Owen
    Owen New Member
    10
    Jun 16, 2004
    Berko Herts
    Car:
    1992 190E 1.8 84K
    Hi Stu
    My dad has a 190E '92 with 260K miles and still going strong on the orginal timing chain.
    Not sure I would let it go that far. I think you have little to worry about for now,
    so enjoy!
    Owen
  5. OP
    OP
    stwat
    stwat MB Enthusiast
    3,175
    Jun 20, 2004
    Sheffield
    Car:
    1989 W126 300 SE
    Hi Owen,
    260k on one chain :eek: Now that is impresive :D
    I think il stop worrying about mine!!!!! :D :D
    cheers,Stu.
  6. JB.
    JB. New Member
    7
    Mar 12, 2003
    :noitacoL
    My 2 litre's done just over 140k on the original timing chain and it's all still running smoothly :)
Share This Page
