Hello !
I've a question in mind ! but before asking it let me explain
as far as i know; there are two types of EZL modules used on the W201's.
The old one that gets the RPM signal from ignition distributor hall sensor & the new one that gets the RPM signal from the flywheel speed sensor.
the question is, will it work if i used the new EZL module with the RPM signal from the ignition distributor's hall speed sensor?
if yes
thank you, but if no
! please explain why
if yes
