hambleford
- Feb 14, 2011
- MB 190E 2.5-16V
Hello Everyone
Has anyone any experience of replacing the gearbox dipstick tube. I have recently had my gearbox overhauled (3 months ago), the garage failed to fit the dipstick tube screw to the engine. As a result the tube has fractured. I need to be be able to extract the section still attached to the gearbox. My question is if I find I cannot withdraw this section due to limited access if I were to remove the gearbox sump cover does this expose the tube and am I able to tap the tube out from below. Also could you cofirm if there is a seal fitted between the tube and where it is attached to the gearbox. Any info would be greatly appreciated.
