Hi everyone,
The oil pressure on my 190e 2.6 is concerning me a little. At hot idle the pressure on the gauge is reading a bit under 0.5bar. When the accelerator is pressed, it quickly goes up to around 2, and at 60mph+ it reads just over 2.5. The engine has about 150k under its belt, emits no nasty noises and is silky smooth.
I've read that ideally, the gauge should be at 3 in all situations other than a hot idle, where it should be at least 0.5.
My questions are essentially - is my engine knackered? If it is, how long do people reckon it'll go on for in this condition? Would people recommend using a thicker oil in it (e.g. 15w/40, 15w/50, 20w50) to try and increase the pressure? I'm not actually sure what grade of oil it has in it at the moment.
Many thanks.
Many thanks.
