Hi everyone,
Ever since I've had my '92 190E 2.6 it's had a bit of an annoying problem (or set of problems), which now seems to be getting worse.
Firstly, it never tends to start very easily. It always does go, but often has to churn for a bit longer than you'd expect, particularly when cold. When the engine does start, it's always quite rough for the first few seconds. There isn't a problem starting when warm, although sometimes you have to release the key first, then it'll fire. Length of time from when it was last used doesn't seem to dictate how long it takes to start, either. It also never seems to fully go up to the high idle speed - even when cold it idles at about 750rpm. The battery is only about 6 months old, so I wouldn't have thought it'd be the culprit.
Secondly, and more importantly, the car often lacks power and has an uneven throttle response. Sometimes you'll try to accelerate and it'll pull crisply and instantly, but more usually it'll hesitate and seems as if there's a flat spot. It seems to happen when the engine's hot and cold. It feels like there's either some sort of fuel blockage, or the acceleration enrichment isn't working. The problem only seems to happen at lowish revs - once you've broken through the flat spot, it pulls ok.
Aside from this problem, when warm the idle speed always seems quite low (about 550rpm on the gauge), and is not 100% smooth and stable. It's not hunting, and the variations aren't visible on the tacho, but you can just hear it and the oil pressure rises/falls slightly at the same time.
So far I've tried replacing the fuel filter, and run some injector cleaner through it, but it doesn't seem to have made any difference. As I mentioned on another post on this forum, the EZL unit fitted when I bought the car was the wrong one (for a 1.8), so I've changed that for a (more) correct one (from a W124 300E, which seems to have almost exactly the same spec as the 190E 2.6 unit). I also replaced the plugs and air filter at the same time - neither were in a very good state.
I was wondering if this might be down to failure (or intermittent failure) of the OVP? I've never had any of the dash lights come on, and the ABS seems to be working. I wonder if there's any way to test the relay, as I'd rather not buy a new one for £75 if that's not the problem. If it's not the OVP, does anyone have any ideas?
Many thanks for any suggestions.
