I've broken the gearbox mount off my 190e auto gearbox when the front coupling on the propshaft broke. Does anyone know if this is repairable or do i have to get a new gearbox?
300-24, saloon and coupe, E300 24 valve diesel estate
you can get a replacement rear cover but you will need a deep 32mm socket and a pretty good air wrench to remove it. When removeing be careful how you pull it off as the gear locking mechanism is there held in by springs. Also on some models there is an oil feeder line that (on mine) fell off.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
