190E Engine Swapping
Merc-Cymru
Manchester
'93 190E
does anyone know anything about replacing the 2.0 engine in a 190E with say a 2.0 190 diesel engine or is it even possible to fit something bigger?
Mark300SL
1962-2010. Gone, but not forgotten.
Anythings possible :) - After all there are a few 5.0 V8 190's around - but without being too picky - If you need to ask then its probably too much work for you.
As the 190's were fitted with engines up to 2.6litres, then these would be the easiest swaps. In an ideal world you need a complete damaged donor car and have the two cars side by side - then move the parts over one at a time until its done. This save lots of frustration going to buy individual parts at extortionate prices! - whatever is left of the donor car after the swap - can be sold off on ebay !
If the 2.6 190 uses a 6 cyl M103 engine then by my reckoning it uses basically the same block as the 3.0 M103 - which in turn uses basically the same block as the 300-24v - so theoretically it should be possible to drop a 300-24v into a 190 with moderate ease - providing you had a 2.6 to start with!
Mark
Champion Modder :)
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
keep your eyes open for a green c230k with 137k on the clock, FMBSH and a carter protection plate under the engine. That was a quality engine I can tell you and it should drop straight into a 190e ;)
Limited Edition
Virginia Beach, VA USA
1993 190E (3)
I know a few people that have swapped a 3.0 M103 engine into 190Es. It's a pretty easy swap.
Regards,
Don
