190E Heater Fan
Discussion in 'Electronics' started by acid2002, Jan 14, 2009.
  1. acid2002
    acid2002 New Member
    4
    Nov 20, 2007
    kent
    Car:
    clk 320
    Hello All
    My heater fan is squeeking and sometimes stops working, how do I get to it.
    thanks in advance.
    Derek
    I think its a 92 model
  2. grober
    grober MB Club Veteran
    27,613
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Disconnect the battery earth strap Remove the plastic air intake cover above the heater plenum chamber that's the "trough" just below the wiper arm. You will have to search for the retaining screws under various rubber sealing strips etc.You should then see a black plastic cylindrical cover held on with 2 screw/bolts the fan + motor is under it. You can then disconnect/ remove it for repair.
Tags:
Share This Page
