Hi, I’m new to the group also new to Mercedes. I feel that I may need some guidance with a project I have taken on. I’m not even sure where I should post this.
I recently I acquired a 1975 280CE coupe auto (I believe this is the W114 with an M110 engine). The vehicle has not moved for at least 20 years and is in a bit of a state. On the good side it has been under cover and prior to being garaged it had quite a bit of work done.
After a bit of a struggle to get petrol through, I suspect fuel pump was low on pressure or pressure control valve stuck, the engine has now started. It seems to be running a little fast for an auto but quite smooth and no serious noises for a car with 400 miles on the clock ( I assume that will be 100,400 miles)
I have stripped out seats and carpets and the first obvious problem is it leaks in water. The main areas where water enters are around the brake pedal and below the rear window. The rear glass seems to have sealant between glass and rubber so I’m thinking it’s leaking between metal and rubber but I’m not sure about removing the chrome trim. Does this just lever out?
At the front I thought the grill by the wipers will take water and must have a drain that could be blocked but the grill seems to be riveted in position and I’m unable to find any drain pipes.
I would like to get the car clean and dry prior to fitting carpets, seats and starting on the mechanics of the vehicle. I would appreciate any suggestions in relation to window trim removal, where to look for leaks, blocked drains and corrosion. Is there a simple idle speed adjustment or is this something I’m going to have to look into a little deeper in the future?
Thank you for reading my post and for any help you may be able to give.
