1980 would be K-Jet.
As above, but also try leaks from the injector seals (they're rubber and go hard), take the air cleaner off, and spray brake cleaner or something flammable where they sit when the engine is running. If you have a leak you will hear a change in pitch. Obviously be careful not to start a fire......
