AndrewMcD
Hi, sorry if this type of question was been asked often.
I'm inheriting / being given an 1984 280ce with about 100k on the clock. It failed it's last MOT in 2007 due to emissions. It then was taken of the road and stored under a tarp for a few years. The current owner bought it, took the tarp off, put a battery and petrol in it and drove it 30 miles to where is is now, mad man. For the past 5 years it's been in a dry garage. So I know it runs and seems to do all it should. I also know it was very damp inside when it was recovered... but the floor pans seem ok. The door window scraper seals are next to useless, so i'm guessing that could be part of the damp issue. And the passenger side door has a corrosion hole in it. Apart from that the body 'seems' ok. The spring on the drives side bonnet hinge has broken. Is that just a case of replacing the spring? And if so is that easy enough?
My plan for the car is to use it as a daily driver. My commute is a not arduous 20 minute drive.
So.... as i'm getting the car for free... is this a worth while punt? Does any of the above make any of you think I should run away. I'm not looking for an instant concourse car, but I would like to over the years to bring it back as best condition as I can. Are parts difficult to get? Are there any good online sources or am I better through main dealers? And am I mad...
Thanks in advance, Andrew.
