1988 190 noise in left hand turns
neilr
my '88 190 (carb model) is making a strange rumbling sound when i execute left hand turns, sounds a bit like a wheel bearing thats gone (but it isnt), theres a slight virabation in the steering when it happens but not much and no sound coming from outside the car.
I cant see anything obviously loose or broken and I'm a bit stumped to be honest.
Could it be something like engine mounts perhaps? The car has 103K miles on it. Rocking the car and bouncing it when stationary makes no strange noises/squeaks etc.
Any ideas?
Thanks.
Neil
Ian B Walker
Freckleton
300-24, saloon and coupe, E300 24 valve diesel estate
I know what that is my friend, happened to me on my ex 190. Its the steering drop arm hitting the exhaust. Either due to as you suspect engine mountings or your exhaust has slipped on the manifold.
pluggers
Staffordshire
CLK 200 kompressor w209
Could be a ball joint on the way out,have you jacked up the car too see if there is any free play in the steering?
OP
OP
N
neilr
thanks for the replies guys, i'l check both those things this week.
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
This should be in a different section, moving...
