1989 500 SEC fuelling issue?
Discussion in 'Engine' started by Roygarth, Nov 9, 2013.
  1. Roygarth
    Roygarth Active Member
    99
    Aug 12, 2009
    Norfolk
    Car:
    1983 W123 230E
    I have just bought an '89 500SEC. It has done very few miles over last 5 or 6 years and may have old fuel.
    If you floor it it accelerates perfectly well. But if you lightly accelerate it misses/wavers around etc.
    I'm hoping a tank of fresh fuel and a bottle of injector cleaner will sort it!
    Any ideas?
    Piers
  2. arfan786
    arfan786 Active Member
    135
    Dec 18, 2012
    west midlands
    Car:
    mercedes benz 560 sec
    hi congrats on your new car.:thumb:
    If the car has been sat around for 5-6 years with old fuel in it my advice would be drain the tank of old fuel and then use fresh fuel and injector cleaner as otherwise you will have other gunk clogging up injectors etc.
  3. ianrandom
    ianrandom Active Member
    998
    Feb 19, 2010
    Berks mainly, UK. Devon too a lot of the time.
    Car:
    1986 420SE, 1990 420SEC, 1989 2CV6.
    Hmm suddenly mine is doing the same.. Injector cleaner tomorrow I think.
  4. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,412
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    First thing is change of plugs, caps and rotor arm...Leads if they look old...
    People just dont change these basic items for some reason and they are the cause of most misfires on these.
    Fuel cleaner may help but I doubt it.
  5. ianrandom
    998
    Feb 19, 2010
    Car:
    New plugs today, the correct Bosch from MB. Rotor cap looks like new, cleaned the contacts anyway, same for the rotor itself. Leads are nearly new.
    Swapped the fuel pump relay and the injection computer, no change.
    Boo :-(
    Got a new filter but the old one is rusted on. Have to order the pipes either side before that gets changed.
    My thoughts are I've sucked up some gunk, I ran it out of petrol before about three times. It's been alright since but maybe that's what it is.
  6. WG M-B
    WG M-B Auhorised Forum Sponsor Authorised Forum Sponsor
    1,898
    May 26, 2011
    N/W london
    Car:
    C63 Wagon in black
    Sounds like a spark problem. I would suspect the coil
  7. ianrandom
    998
    Feb 19, 2010
    Car:
    Thanks, I've been thinking of the coil too actually.
    Could it produce behaviour like mine and the thread owners?
  8. ianrandom
    998
    Feb 19, 2010
    Car:
    I changed the EHA today after reading via Google that an owner with exactly or symptoms fixed his car by having that changed.
    Thought it had worked, but nah. Admittedly it was off a non running spares car, but no difference.
    Roygarth, might work for you. It's only two screws, love repairs like that, lol.
  9. OP
    OP
    Roygarth
    99
    Aug 12, 2009
    Norfolk
    Car:
    1983 W123 230E
    Update!
    Car now accelerates and cruises fine but wanders/hunts badly when stationary. And often dies when you go from park into drive or reverse.
    Has had clean up of everything, new plugs, leads, fuel pumps.
    Any ideas?
    Piers
  10. John Jones Jr
    John Jones Jr MB Enthusiast
    4,621
    Mar 23, 2013
    London & Dublin
    Car:
    Mazda MX5 10AE, W201 2.5-16, W202 230K Sport man, Honda Accord & Suzuki 'Ricer'.
    There's several things I'd look at, like the Alternator regulator, OVP relay, Vacuum leaks etc. But first I'd get the mixture checked & adjusted. An hours labour charge with someone that knows KE-Jet would be well worth the expense. Cracking car BTW, enjoy.
  11. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    Check the insulator disk under the rotor arm. They can crack and allow HT voltage to short tot eh distributor body.
Share This Page
