Dontastic
Hello Mercedes enthusiasts i hope this finds you well.
My 1989 300sl has developed a bewildering display of non/poor running symptoms and having spent the last few days learning/studying all about the ke jetronic system im well informed but still slightly confused as to the exact fault so here goes: Now i may not of gone about this in the correct order but went about it nevertheless.Lol.
She(or He@the risk of sexism!
) was running great,then started idling a tiny bit rough and became difficult to start when warm so i changed the plugs,air filter,distributor cap,rotor arm and fuel filter all of correct specification and that didn't make the difference i was hoping for.
Then the economy gauge ceased working,stuck to the right(Red)but still ran ok ,if but a bit rough.
Later when attempting to start warm a LOUD! backfire occurred and NO Starty:fail.Towed home and set to work on diagnosing problems.
Started with a check of all vacuum pipes and Bingo!(No thxs! lol) found the inlet manifold grey vacuum pipe off so plugged back in and...nothing
.Further up the pipe found where splits into 3 check valves one of which had almost disintegrated but was able to tape up temporarily so as to eliminate and she now starts(And economy gauge works too!) but will not idle without manual use of accelerator and really rough even when kept running until up to engine temp,still just stalls.
I find that if i disconnect the idle control valve(been removed and cleaned and shown to close when voltage applied) when warm she will idle on her own but a little high 1000-1200rpm and as soon as i re connect it cuts out.
Poss engine temp sender?
Poss cold start valve?
How can i check idle valve.cold start,engine temp sender correctly?
Is it lamba sensor,how to check?
I also have a new ovp relay fitted.
I think i will stop there,have some lunch and rest my head while eagerly awaiting some replies from you amazing r107 specialists!!
