anfieldassasin
- Nov 23, 2014
- Location
- Essex
- 1988 300ce, E46 323ci, 1990 230ce C124 (sold), cl203 180k (other half)
Hi all,
1st post but long time surfer of the forum!! I'm a weekend novice DIY'r when time allows mainly thanks to all post i have read on this forum!
have a 1990 230ce 8v M102 engine (NonCat and duplex chain driven! ) coupe with 95k miles
I bought it a few months ago with 94k on it, it was cheap enough as no history but the condition checked out apart from a rough idle.
So the problem when i got the car was:
fluctuating idle when engine was cold and warm. it would fluctuate between 800-1000 and the car would shake (not shake as if its about to stall) but rock me in my seat. This would occur in all gears (P, N, D) except Reverse!?
Things I've done so far:
oil (Mobil1) + Filter (bosch)
air filter
Bosch Rotor arm
Bosch Distributor cap
Fuel filter
Power steering fluid + Filter
gearbox fluid + filter
x4 Bosch HD7C plugs
Bosch HT leads
traced vacum leaks and repaired (inc looking at rubber boot under air plate)
removed EZL cleaned and new heat sink applied
x4 Bosch injectors + seals
idle control valve (ICV) out and cleaned with carb cleaner (twice)
all hoses from crankcase to ICV and to intake manifold replaced
Fan temperature switch replaced
Idle switch position reset
x2 engine mounts
transmission mount
other non-related stuff have included window motors, regulators, steering damper, tidying up the alloys, ARB bushes, New radiatior + coolant (MB Spec) etc.
Status after all this:
Developed loud ticking noise from cold start which goes once engine warm or after 5-7mins driving......sounds like hydraulic lifter
The idle has improved, in park it now idles at 800-900 and in drive around 700-800. The car still shakes!! the idle fluctuates much less than before like + or - 50 mostly with an occasional (once or twice) fluctuation of +or - 100-200.
The idle problem no longer occurs from a cold start (replaced by the ticking lifters ) but now only occurs once the engine is warmed up. oddly, if i put the car in neutral once warm it is when the idle and shaking is the most.
Its a liveable problem and does not seem to affect the cars whilst driving but i just want to get to the bottom of whats causing this out of principle more than anything! failsorry been told i have obsessional traits!!) as its driving me not knowing where the problems lies!
Any Ideas?
Thanks in Advance and sorry for the long and dramatic post but its sunday and past my bed time
Sam
air filter
Bosch Rotor arm
Fuel filter
x4 Bosch HD7C plugs
Bosch HT leads
x2 engine mounts
transmission mount
Any Ideas?
Sam
