IBN
Hi All,
My R129 failed to start after storage, just cranking over. Checked spark and looks ok.
Fuel pump is not running when key on or cranking. checked voltage across pump when key on/cranking and zero volts, so assume its not getting any.
I'm not sure what relay is the right one and how to bypass it to test. I have attached a picture of the relay box - can you help me?
Is there anything else that can go wrong that I can check?
thanks
Ian
thanks
Ian
