1990 W124 200E, missing a gear, o/d, or fine?
Cleggmeister
East Kilbride
1990 W124 200E
Hi folks,
At 60mph my gal is doing around 3400rpm and would love another gear. I don't think there is another in the transmission but wanted to post in case I'm missing a trick?
Many thanks.
Cleggy.
E55BOF
South Bucks
CLS 350 SB, SLK55, FJR1300,
When you say 'my gal', are you referring to your car, or your current squeeze who is nicer than an E55?
OP
OP
Cleggmeister
Cleggmeister
East Kilbride
1990 W124 200E
They're one and the same, i.e. my W124 E200. Actually she's doing 3100rpm at 60mph - not quite as bad as I made out, but still seems to be begging for another cog...
grober
MB Master
Perth, Scotland
W204 ESTATE
Are you sure you have the original gearbox rear differential combo. With older cars sometimes sometimes random replacement via second hand parts can mean a mismatch. Other possibility is are you sure you are in 3rd and not 4th? Manually select third and watch the revs then let the box "change up". The 2 litre engined w124 cars may well have a higher back axle ratio [lower gearing] to give adequate acceleration at the expense of top speed.
hotrodder
south east
'93 320te
Sounds about right to me, i've a vague recollection that 70mph is around 3500 rpm in the smaller engined 124s (it's near as damn it 3k rpm in a 320 with a 4 speed auto). Generally speaking cars were lower geared back then 20mph/1000rpm in top wasn't uncommon and, as said, power to weight ratio influences things. In the compromise between acceleration and top speed MB typically favoured acceleration a little more than other marques- my 320 for example is one of the few cars i've owned that (on paper at least) can pull top gear all the way to the rev limiter i.e. top speed is limited by gearing rather than power.
Gearbox is the thing that ages/lets these down IMO and it's not helped by the silly 1st/2nd gear deal. Doesn't apply to all (especially later) models but many of 'em pull away in second by default with 1st gear only used when you boot it off the line and soooo short it's practically useless effectively turning a 4 speed box into one with 3 gears
OP
OP
Cleggmeister
Cleggmeister
East Kilbride
1990 W124 200E
Thanks all for the replies. I'm certain al is well having counted up the gears under hard and soft acceleration. There are definitely four present and correct, just a shame the fourth is not a little taller. That said, driving around at 55mph is fine with me, I averaged 40 to the gallon on a long run recently...
