IMD
Hi all,
Happy New Year to you all.
I'm after a little advice. I have a 1990 W124 230e saloon. It's a low compression engine model (spent its first 3 years in Africa) and is generally great condition, well looked after, low mileage etc. But there is a frustrating vibration!
In neutral, at standstill the car ticks over very smoothly. As soon as you engage drive, with your foot on the brake pedal, the car engages gear and starts vibrating. This is present a little when driving, but most noticeable when engaging drive. A mechanic friend said it could be the engine mounts, although he said they were not too worn from a quick look. When the ignition is started there is a slight jolt...which I've heard could be another indication of the mounts going?
Does anyone have any suggestions? Is it an engine mount issue, a gearbox issue or something else.
Your help in making my car a little smoother and less frustrating would be great!
Cheers
Ian
Cheers
Ian
