GregE240
Hi folks,
Wonder if anyone can shed some light on this for me?
I've just got back from a 1700 mile tour of Germany, including visits to RUF and the Schlumpf museum (highly recommended). My partner and I took the SL, and it performed faultlessly, aside from an occasional starting issue, which I thought I'd had fixed.
The problem is this: every so often, you go to start the car, turn the key and you DON'T get all the dash lights come on. If you continue to turn the engine will turn over, but will not start. You then have to turn the key back to 0 and try again. Next time it might start.....or it might not. During the trip it was mostly okay, just a little heart in mouth "will it start" moment every now and again.
I've had the sleeve that the ignition barrel fits into replaced, and this seemed to do the trick, but alas, the problem surfaced again. Another mechanic has cable tied the main ignition power feed to the switch as they thought it might have worked loose, but that hasn't done the trick either.
The problem occurs regardless of whether the engine is hot or cold.
Any ideas? I'm open to suggestions!
Thanks,
Greg
Thanks,
Greg
