I lowered my driver window and it would not go back up I checked the fuse it was OK. I raised the centre consul,no loose wires, so I changed the connections over and the passenger window worked on the drivers switch and the passenger switch the drivers window did not work on either. I have changed the window motor as it was faulty but now I can,t get any power to the window and the front roof latches will not open but will close again if I first open them manually.
