1992 W124 300TD - Noisy Tappets
tomghannon
Co. Clare, Ireland
1992 W124 300TD, 2001 W210 E320CDI
Hi all,
Long time lurker here - first time poster!
As the title says, I have a 1992 W124 300TD with 231,000 miles.
Mechanically, the car has been faultless - however it has a persistent problem with what I assume are noisy tappets. I change the oil and filter every 3000 miles and in the last two changes I ran an engine flush which doesn't seem to have cured the problem. I use 5w30 semi-synthetic oil as advised by a number of mechanic friends.
My questions, is there anything else I can do along with or instead of the engine flush and also would I be better off using fully synthetic oil.
krimat2005
Littlehampton, West Sussex
Mercedes W124 300D/ S203 220cdi
Hi, change the tappets, they cost about £10-12 each from gsf, well i'm suggesting get them all 12 done. if you have a friendly mechanic who knows what he's doing it's 2 hrs job with a pint of lager...
230K
Belfast
09 E320 cdi Sport Estate, 98 E300TD Estate, 99 SL 500
Hi
I agree, just change them, i tried changing just 2 to start with and then bit the bullet and bought the remaining 10 and she has been as silent as a mouse chewing paper since and that was 7 years ago!!
Easy to change too
230K
spock500
Milton Keynes
S124
Hi all,
Given the miles I might be tempted to try 10/40w to see if that makes a difference.
What spec oil do MB recommend for this engine?
If you do change them give these guys a try, paid about £8ish each for mine :thumb:
UltraParts
sub_zero
kuwait
W124 E220 1995
Pardon me all, what do you mean by tappets?
I tried Google to translate it, Google translated it to another word I don't know :confused:
compress ignite
32 degrees North by 81 degrees West
'90 300D 2.5
In Yank speak
Hydraulic Lifters(They fit in between the Valve Stem and the Camshaft.On top of the Valve)
OP
OP
T
tomghannon
Co. Clare, Ireland
Thanks for all the replies so far.
Just been quoted €32.75 ea + VAT = €39.62 (x12) = €475.44 from my local friendly main stealer.
I assume (hope) I can get these cheaper elsewhere.
Does know the Mercedes part no and any suggestions on who to try to obtain these.
Thanks.
spock500
Milton Keynes
S124
Thanks.
Did you try the link in my post?
snoopy
Also very possibly injector knock, they'll be worn at that mileage.
Loosen each one of (13mm spanner) one by one and see if knock stops, if so you've found it.
Do you run on comedy fuel?
I have a working spare for sale if you need it, I bought 6 from a breakers and only needed 5 for my 250d. It's been tested. See: http://gb.adings.com/?classifieds;module=view;id=163
krimat2005
try GSF car parts, they are about £12, but if you ask nicely they might give you discount. anyway, staff they selling is OEM INA, so I wouldn't think twice.
