riffraffjazz
- Nov 16, 2016
- 450SLC
Hi, I have a 5 speed automatic 1993 E320 Cabriolet. Problem is that it is not going to 5th, removed transmission control module (TCM) and the car shifts straight from 3rd to 5th, (as I was told it would), good to know I have 5th.
I want to know where the "D" switch is, I have removed center console as I've been told it is located there, all is see is a couple of small shafts heading front and rear. I have read that if the switch is faulty you get no 5th.
One sheet says to check for loose connections at the Throttle valve switch and between TCM and transmission, both seem to be OK.
Any help with "D" switch location would be appreciated, Cheers, Paul.
