tmwsccsh
- Sep 8, 2012
- Location
- Letchworth, Hertfordshire
- 1998 CL420, 1994 Ford Mustang Convertible
Hi all,
Slight disaster - see below.
Some background. Hard top has been on all winter and today was the day for it to come off. Some may recall I had issues last year with a leaky main piston so was going to change that for a good one at the same time.
The hard top would not shift initially at all - it was whirring but would not move - after a few attempts it finally released and off it came.
I got the passenger side main piston out and replaced (took a couple of hours) and tested all that no problem at all.
Just did a quick drive with the roof down for the first time this year and got back to park her up for the day. Hit the button to put the roof up and all was good and made the right noises but I noticed that the red light on the roof button didn't go out. Couldn't see why so got out and had a look and the attached is what I spotted. The other side is down fine and locked.
If you try to push the bit that is sticking up down it won't budge - as if the locking mechanism underneath has kicked in.
So, key back in and operate the roof again - it makes a single click and then nothing. The windows don't go down and there's not even an attempt to move anything - just silence. The red light for the roof starts to flash after a second or so suggesting something is wrong.
But, more importantly, how can I sort this quickly, even if it's just to get the roof back into a properly locked position. There's rain due tonight!
It's not fluid in the system as I have already checked that (and had to top it up anyway as part of the changing of the main lift piston anyway).
Thanks in urgent advance!
Regards
Tim Watts
Regards
Tim Watts
