holtons
I’ve trawled all the posts related to this but can’t find an answer to my problem.
About 10 seconds after locking the door with the key fob, the indicators flash and keep doing so until I unlock the car. I’ve read that this to warn you there is an alarm fault. I’ve found loads of posts about the Scorpion alarm but I don’t believe this is one as the alarm is integrated into the central Locking system, there is no separate fob for the alarm. Some posts suggest the battery in the alarm siren could be dead but I don’t know where the siren is located.
As has been mentioned in a few posts, I looked behind the passenger floor panel for a control unit to try to identify the make but there is only a red box with 154 written on it (see photos) which I believe is the airbag test connector. I’ve also added a photo of one of the sensors mounted on the A pillar plus one of a switch and led on the dash which looks very after-market.
anyone know what type of alarm this is and where the siren might be located?
thanks in advance
thanks in advance
