spock500
Hi folks,
Just reaching out to see if there is much interest on part finished S124 diesel.
Please PM or call for full details but main points below - open to offers.
1996 S124 300D, 127k documented miles - currently SORN
Work done.
Refurbished head, skimmed, new seats, glow plugs, injector nozzles, engine oil flush.
New oil pipes, cables, battery, ATF change, new filter, diff oil change.
Sunroof overhauled, replaced motor.
Work required
Both MB wings have been repaired but need paint along with two repairs to lower front corners. I used a resin but this could be cut out in favor of sheet steel if required.
Other bad points several scratches and car park dings which are on the 'to do' list.
Windscreen to both edges has started to de-laminate, not hugely noticeable but worth mentioning.
There's a ton of extra 124 parts including four 8 hole hole alloy wheels (need refurb) as I bought a second donor car.
Only a handful in this colour and mostly petrol.
Work done.
Work required
