1996 W124 coupe Infra red issues
tommyboy40
Ireland
R129 SL500 W124 220CE x 2 Smart 450 cabriolet. C215 CL500
Hi all, I'm having some issues with one of the w124's. It locks perfectly with the button, red light flashes as it should. It doesn't however unlock, the light goes green but it makes no effort to unlock, no pump running. Any ideas? Cheers in advance
Dec
C180,A.
Unplug the vacuum pump for 15 minutes to see if this might reset something. Check that all electrical connections to the pump are clean and free from corrosion.
Does turning the key in the door or boot lock have any effect on the central locking vacuum pump?
Check fuses also.
Dec
OP
OP
tommyboy40
tommyboy40
Ireland
Hi Dec, thanks for the reply. The pump works perfectly if I use the key and the button on the fob locks the doors and sets the alarm. When you push the button to unlock the car, the green light flashed and the alarm is turned off but the door doesn't unlock and the pump doesnt run
Dec
C180,A.
Any chance of a picture of the vacuum pump and its Yellow tubes, it’s located under the rear seat inside a foam rubber box.
Dec
OP
OP
tommyboy40
tommyboy40
Ireland
I'll grab one on Monday when I get it back from the painters
OP
OP
tommyboy40
tommyboy40
Ireland
Bit of a thread resurrection but no closer to solving my issue. I have two key fobs, one of which is brand new. The central locking works perfectly with the key from either the passenger door lock or the boot. It locks perfectly with the remote but refuses to unlock. When you push the remote button you can hear the relay in the fuse box click and the green Led flashes but no unlocking. It has fixed itself on two occasions and worked perfectly for a day or so. Also it tends to lock and unlock itself randomly while driving, not all the time, just occasionally.
Dec
C180,A.
Do you have a central locking switch on the dash to lock or unlock the doors while the ignition is ON, if so will it lock and unlock the doors?
Dec
OP
OP
tommyboy40
tommyboy40
Ireland
No switch on the dash Dec
OP
OP
tommyboy40
tommyboy40
Ireland
On a side note, that was post 30:bannana:
Dec
C180,A.
It was worth your while coming back then, we all thought you were dead as it’s been so long since you were on here.
Your vacuum pump is under the rear seat, it would seem to be the problem, would you be adventuress enough to in take it apart and inspect it for damage to the Printed Circuit Board that is inside it?
Photographs would be useful.
Dec
OP
OP
tommyboy40
tommyboy40
Ireland
Well Dec the 3 weeks it wasting to take to paint the car turned into 3 months. I'll pull the pump and take it apart. I could swop the pump from the other W124 and try that too. Thanks for the help on this
OP
OP
tommyboy40
tommyboy40
Ireland
This one can be marked solved. Thanks Dec for sound advice. I pulled the pump from my other W124 and swopped them over. the faulty pump was held together with a cable tie, evidence of a previous repair. I'll dismantle it when I've time and see if it can't be fixed
I also changed the v belt, €10 cheaper for the genuine part than a spurious one
