Futureoils.com
I just got my 97 C250TD back after 2 weeks in the garage after having the turbo, exhaust manifold seals and main engine rocker gasket seal replaced in a number of attempts to stop the engine consuming oil at a rate of 1.5 litres every 300 miles. The exhaust smoke is clear at low revs but the mechanic has told me that there is excessive amounts of oil being ejected after he pulled off the breather at higher revs. The engine seems to run fine when it has reached normal operating temperature but occasionally the power seems strangled for the first few minutes when driving from a cold start and this is accompanied by a slightly blue puff of smoke from the exhaust. (When this happens I get a slight smell of smoking rubber coming into the car if the dashboard fan is switched on) He seems to think the oil ring seals are gone which is quite shocking for a car that has supposedly covered only 70,000 miles low city mileage. (HPI checked) I purchased the car 2 years ago with 52,000 on the clock and have been running it on rapeseed oil (with a coolant heat exchanger) ever since regularly changing the engine oil and filters every 6000 miles. My mechanic is now convinced the only way to stop this oil leak is to take out and strip down the engine. (which I am prepared to do if this is the only option) He has advised me to drop the car back to him next week so he can take out the engine for further investigation. He informed me that it looks like I will have to get a new head gasket set and might as well replace the valve stem seals as there is back pressure blowing the oil dip stick up out of the engine putting the new alternator at risk of one again being covered in oil.
Any advice on how I can finally resolve this 6 month ongoing problem would be greatly appreciated. From what he is telling me it's looking like a 1500 euro job to put right. I was half thinking of trying a litre of Ametech Engine Restore Oil in the next oil change. Has anyone else tried this or is it better to swallow the cost of the engine overhaul longterm?
Does anyone know the cheapest place to buy the full head gasket set and valve stem seals?
Many thanks,
Dylan
Many thanks,
Dylan
