Borris1954
- Feb 4, 2013
- Location
- South Bucks
- S204 C 250 CGI BlueEFFICIENCY, R170 SLK 230, B 180d AMG Line
As it was such a lovely day yesterday the SLK was taken out for its first real run of the year. As it's not used greatly (especially in the winter) I fairly regularly charge the battery which I last did about two/three weeks ago.
"Senior Management" and I had a lovely drive in the country with the top down and enjoyed a great pub lunch before returning home. Parked on the drive I went to close the roof - absolutely zilch happened. No light on the switch, no noises from anywhere - nothing at all. As the engine was still running I thought I would turn it off and restart and try again. Turned the key - a small click and the starter motor struggled but failed to turn the engine over - battery as flat as pancake. Given we had just been driving for a while that was not what I expected to happen. So I jump started the car and with the leads still in place closed the roof. I connected up my battery charger (not really expecting it to do much) and went off to look at battery prices. The upshot is that the battery charged normally and held charge overnight and starts car fine today. So not the battery!
A voltage check reveals the battery voltage is about 12.2V until I start the car at which point it falls under load of running engine to about 11.4V. My attention next turned to the K56 crash relay. This appears all good with same voltage on both the G and battery terminals and an ohmmeter check reveals the relay is definitely closed when the engines running and open when it's not - all good.
So it looks like the alternator is defective.... BUT......
What I don't quite understand is a symptom I should have notice much earlier and may have been there for ages (possible even since I bought the car 3 years ago). When I turn the ignition on not all the warning lights come on and stay on until you start the engine as you would expect - one being the battery light! Also some flash on very briefly and then go out - the oil pressure being one. I'm wondering if they are being extinguished when the K56 relay closes.
I have searched and googled but can't find this behaviour described anywhere - has anyone seen it before?
I guess the next step is to get the car up in the air and take a look at the alternator but I am just a little nervous the issue may still be elsewhere.
