slippy
- Dec 28, 2007
- Location
- Mexborough, South Yorkshire.
- Jaguar X type 2.2SE / SLK 230k
Hi, I have my first real problem with my SLK, its got me (& others) stumped! This is my toy & doesnt come out often.
I replaced the cam sensor magnet with a genuine one from Mercedes & fitted it with the genuine Merc sealant as I had a slight weep of oil from it. The electrical plug that fits onto it was slightly damaged, so this was replaced & the breather pipe on top of the engine was also split, this was replaced too.
Once the above parts were fitted I started the car & all seemed well.
A few weeks later, I started the car & all seemed well again, I reversed it out of the garage, no problems. I set off down the road & once upto about 1800 revs, it felt like it was running on 3 cylinders.
I didn't have time to do anything so put it back in the garage. Checked again a few days later & it started fine, reversed out fine, set off & same thing happened. The same fault occurs even if the car is in PARK & you gently increase the revs to about 1800rpm.
I had the codes read & it showed a missfire on cylinders 3 & 4 so I replaced the plugs, coil packs & plug leads. I also cleaned the MAF with electrical solvant cleaner. The codes were cleared & tried again. The car starts up perfect, ticks over fine but as soon as the car hits a certain amount of revs the missfire happens again. If you stop the engine & immediately start it again, its fine untill you set off?
I cant drive the car to a garage so Ive had an auto electrician out who read the codes, he checked the feed to the coils & said they were ok.
I cant drive it to a garage & I have since thrown away the old cam sensor magnet so I cant re fit that.......Any ideas please??
