acehighdan
- Dec 18, 2014
- MB 1997 W202 C230
History: I bought a 1997 w202 C230 from a friend of mine.
for personal reasons i am unable at this time to put insurance on the car so it has been sitting in my garage for the last month or so...
about every 3 to 4 days i start it up just to keep the motor in good running order and whatever other benefits that may also some with it.
a few days ago i go to start the car and notice the cars battery is completely dead (accidentally left a light on in the cab).
while trying to open the car with the car fob before realizing the cars battery was dead i noticed also the fobs battery was also dead.
anyway i bought new batteries for the fob and then i jump started the car by hooking up the the car battery in the trunk (boot) to my brothers car and it jump started as expected without any issues or reason for concern, i left the car running for about 20 min to allow the battery to charge up...
i then parked the car back into the garage and a few days later tried to start the car again, and it just wont start....
my friend that im buying the car from has looked at the relays in under the hood, and in the boot as well and didnt notice any blown fuses/relays.
the car will crank, but it just wont start.
Observations:
1: the car will only crank if the key is quickly turned from the off position to the ignition position, if the car is first set to the on position for a few seconds then cranked to the ignition position, the car wont even try to crank
2: if my understanding is correct... if the immobilizer is stopping the car from starting, the red/green lights on my rear view mirror will blink alternatively while trying to start the car.... i am not getting any blinking of any kind (but the lights do work, as it will blink red or green respectively when i am locking or unlocking the car with the fob)
3: the ignition feels.... mushy, kind of like your break will feel if you need to bleed your break lines (this only started recently)
4: there was a couple of times it successfully ignited, but it was only for a split second, maybe 0.5 seconds before it shut off.... its as if the gas/petrol was cut off from the engine or something
5: the car has about 20 - 25 liters of petrol in the tank
I do NOT know much about cars, this is only my second time ever having a car, so if i do get any responses from this post, please try to keep in mind that your responding to a guy that doesnt know the difference between a flywheel and a clutch plate.
I appreciate any and all ideas you guys may throw my way
Thanks in advance
Dan
Observations:
Thanks in advance
Dan
