1999 e 320 avant garde reliability diesel
ricardo62
ipswich
e320
ok basically can any of my learned colleagues tell me if the aforesaid vehicle has any known weaknesses in its design ,that I should look out for .
is it reliable and also can anyone enlighten me as to what the strange knurled plastic screw with a crescent shaped plastic window is on the side of the air filter box is? it does not move when I tried to turn it ? what is its role ?
Hi
Did you find out what this is for ? I have the same and don't know either, perhaps one of our learned MB Specialist can enlighten us please
Hi
hi bazzer yes I did I googled airbox e320 and found out it is a indicator to let you know when filter needs changing ,apparently the more the filter gets blocked the more red shows and when its fully red it means your filter is blocked , assuming it works? and the screw is to reset it when you have fitted a new filter?
Hi
It just tells how clogged up your airfilter is...in percentages.
Thanks Richardo you are a Star, I have often wondered what this was for and then I have forgotten to ask, Good Question with a Positive answer
Thanks again
BAZZER1:thumb::thumb:
Just checked and it is showing white all round, so presuming that it is working, my filter is ok.:thumb:
Thanks again Guys
BAZZER1
