19s on a w204 2012 C Class coupe
Kid_Dav
C Coupe AMG Sport
An you put 19 inch alloys on a new C class coupe? Mercedes only supply the car with a choice of 18" alloys and I believe 35mm profile tyres. Would like to go to 19s and put the C63 multi spokes on, is this poss?
sinewave
Cheshire
BMW 520 M-Sport Touring, Kawasaki ZX10R KRT (AMG Eater!)
C63 Alloys may well have a significantly different offsett so check before you dive in and buy some.
Take a front and rear wheel off yours and check what ET is atmped on the back of the wheel and go from there.
V12
Southampton
S320CDI LWB
Et45 8j on the front. Et 54 9j on the back. The 19s stick out about 5mm wider than the 18s do.
Magoo
Edinburgh
ML280 Ed10 & C350 Coupe
I'd be interested in doing the same. Any warranty or handling issues people know about?
sinewave
Cheshire
That seems to be the problem from previous posts.
There quite an unusual offset so getting aftermarket wheels is trickier.
Having said that is the OP's car a C63 or another model?
Other C series probably have diff offsets hence my initial statement.
V12
Southampton
S320CDI LWB
Afaik the track is the same on all 204 apart from the b.s. As long as you are fitting genuine wheels there is no problem.
kamalpatel12448
London
C63 (W204) and C240 (W202) - just not at the same time!
I know the fronttrack on the C63 is wider and both front wings are wider too, so there might be some gotchas to check before doing this. Also, from experience I have can tell you that you have to take good care of the diamond cut finishon the 19" wheels. On the standard tyre size the rear wheels have no rim protection = high risk of damage, so I stepped up to 265/30.
Sorry I can't be of more help.
Kamal
V12
Southampton
S320CDI LWB
Offset on the wheels is the same and they fit on the saloon. Do they use different suspension on the coupe? How do you know the track is wider?
kamalpatel12448
London
Can't remember the difference exactly but read this somewhere when I was looking to buy the C63, also makes it more prone to catching an edge on width restricted gates too :-(. I'll see if I can find it. I think it might have been the AMG book or manual, external dimensions are different too - I was building my garage at the time of buying hence I remember this.
