calgonis
- Sep 22, 2009
- Location
- St Leonards on Sea
- C230 Sold / 69' VW Devon Delux camper / BMW M135i
I have been running my C32 for 1 year and thought I would show an informative view of what it takes to keep it happy.
Background:
Car arrived with 72k and FULL MB Service History
Essential maintenance required in the last year:
Oil Burning smell - New rocket cover gaskets and seals and I had fresh Mobile 1 put in
Bleeding the brakes due to brake failure on motorway (water found in brake fluid)
New front disks and pads all round
'B' Service + garage found water in my brake fluid again and a missing part under my bonnet that should stop rain water getting into the brake fluid apparently! New part and brake fluid change again.
Snapped coil springs replaced
Both headlights went dim and one had the internal levelling mechanism broken. Replaced both headlights with facelift style ones.
Repaired wiring in front drivers electric seat as the controls stopped working and just blew fuses as soon as you tried to make them move.
Repaired mounting bracket on passenger seat.
I/C pump failed replaced with modified Johnson CM30 unit
I live with:
Air Con Stepper motor/s doing the clicky dash thing started about 3 months ago
Bottom of both heated seats have failed heater elements since purchase
Modifications:
Code 3 Pully
Two Angel tuning remaps first one for a standard car and the second for the Pully upgrade
Johnson CM30 I/C pump
Look Improvements over a year:
Facelift style headlights
Command Center brand new knobs fitted (quite worn)
New chrome metal gear plate added to replace flakey old plastic one
Alloy wheels all refurbed
Center caps replaced
Wheel nut covers added
Not got round to yet:
CD changer jamming.
Drivers door mirror loose
One of the NEW brake disks feels like it has warped under heavy braking
The window wipers have started to make a intermittent clunking on high speed wipe
Warning triangle holder in boot broken since purchase
Rear demister stopped working
Steering wheel a bit worn on leather could do with refurb or replace.
It's lucky I really like the car
I wont actually put the costs down as I would rather not know the total spent. If you are getting one I would put aside a realistic £250 a month on essential maintenance based on my experience. Most things I have repaired / replaced by a garage.
Anyone else had a similar experience with their car?
Background:
I live with:
Modifications:
Code 3 Pully
CD changer jamming.
