i am haveing problems with my cozy, i recently changed the fuel presure regulator because it had a internal fuel leak from it, and the car used to not idle after it became warm, the leak stoped but still not idleing, any ideas????
can we be clear, not idling = stalling? or racing?
it is worth checking the continuity of throttle body microswitch, the throttle linkage microswitch and the idle circuit rubber hoses for leaks. as has been said the idle valve could be sticking with carbon build up, but i doubt it. also you need to check the co at idle if it is pre cat, or the lambda values if cat. ooh, and the coolant temp sensor values, around 250 ohms when hot, but anything under about 400 should be ok.
