MisterAdam
Do many/any people on here run 20's on their CLS???
I've just bought some 20's for my CLS, just need some help as to if they will fit etc. It does not have the airmatic suspension, has the normal spring and damper set up. New wheel spec's are:-
Front - 20x8.5 ET35 with 255x35x20 tyre
Rear - 20x10 ET32 with 275x35x20 tyre
Will I have any rubbing issues? I've offered the front wheel up to the hub and the tyre is very close to the suspension arm coming off the top of the hub. I'm looking at putting a 3-5mm spacer on the front to improve the fitment slightly aswell.
Can anyone advise if these will fit?
If all is well and they fit, I'll be looking at putting some H&R lowering springs on to drop the car 25-30mm, am I going to be running into rubbing problems if I do this with these wheel specs?
I've asked the same question on MBWorld as a lot of the Yank's seem to run big wheels, but I am wondering if anyone in the UK does?
Any help or guidance will be greatly appriciated
