2000 C240 fuse diagram + fuse 53 (engine electronics)
Aaron91
England
2000 C240 (W203 M112)
Hi. I've searched around but haven't been able to find an answer to this.
I recently bought a 2000 C240 (W203 M112) and this fuse diagram came with it (images attached below).
Is this the correct one? I ask because I was pointed towards a different one online which looks almost identical but has different fuse ratings for certain fuses. E.g. There's another W203 fuse diagram online which says fuse 53 should be 15A whereas mine says 25A.
If this fuse diagram that I have is correct then fuse 53 (engine electronics) in my car is underrated as there's currently a 15A fuse in.
Can I just replace this fuse or will it mess up the engine electronics?
Think it’s the correct diagram, you’ll be ok to change the fuse just to it with the key off.
