[SOLVED] 2000 clk230 avandgarde
Discussion in 'Bodywork' started by samdogg, Jun 13, 2011.
  1. samdogg
    samdogg New Member
    12
    Jun 11, 2011
    Stranraer Scotland
    Car:
    clk230 avantgarde,mazda mx5 hardtop convertable
    I have a 230 clk 2000. the boot lid has stopped working from the interior switch and the remote. I have tried the metal key which will not turn either way. I have also tried lubing,now the battery is flat and have no way of getting into the boot though I can access the interior..any ideas anyone
  2. stevesey
    stevesey Hardcore MB Enthusiast
    2,969
    Sep 3, 2007
    Bristol
    Car:
    Alfa 156 1.8TS
    You should find a +ve terminal under the bonnet, passenger side, near the bulkhead on the inner wing. Should enable you to charge the battery.
    As for the boot - have you tried wd40 in the lock and lots of patience wiggling the key - they can often be freed up after a while (hours, not minutes).
  3. OP
    OP
    samdogg
    samdogg New Member
    12
    Jun 11, 2011
    Stranraer Scotland
    Car:
    Can I charge it with only one terminal..? and thanks stevie
  4. Will
    Will MB Club Veteran
    11,182
    Jan 21, 2003
    Surrey
    Car:
    GL63 AMG / S211 E55K AMG / 190E 2.3-16 / 190E 2.5-16 / Porsche 911
    The whole car is negative earthed. The power point mentioned by Steve is a positive connection/terminal.
    Use an exposed area of metalwork, a metal bracket on the engine for example to connect the negative of some booster cables to a spare battery or suitable charger :)
  5. OP
    OP
    samdogg
    samdogg New Member
    12
    Jun 11, 2011
    Stranraer Scotland
    Car:
    Thanks Will my job at 9am tomorrow
  6. OP
    OP
    samdogg
    samdogg New Member
    12
    Jun 11, 2011
    Stranraer Scotland
    Car:
    Thanks to all who helped car running and blow me down and call me a skoda but the boot now works from inside the car.If anyone else has a boot problem make sure you never locked it independently of the rest of the car as you can do this.
  7. SamR
    SamR Active Member
    64
    Nov 29, 2004
    Herts
    Car:
    E220CDI
    Just fixed it for my brother's CLK too, many thanks :thumb:
Share This Page
