Good job.
I’d have been very wary of taking wet and dry to my headlights , but that has turned out really nice
Top job mate, well done.Had a spare moment, so decided to detail the plastic lens using 2000 grit wet & dry paper and then compound followed by polish. It came out really good and pleased with the result
View attachment 123724View attachment 123725View attachment 123726View attachment 123727
Cheers buddy, it was a pleasure to meet you, i gained some valuable insights and tips . Hope to see your clk63 at the next meet.Top job mate, well done.
Great to see your car up close last weekend too.
Can’t say I’ve seen many of the E63 wagons.
Actually, can’t remember seeing one in person at all!
It's good to know that result is achievable using the products you did.I used very minimal material, as the lens just needed light refreshing. I used 2000 grit wrapped around a sandpaper block by hand and had a spray bottle with a little dishwashing liquid to get the wet sanding paper moving and unclogged. I then used a rotary polisher at speed setting 1-2 and compound of your choice. I use Farecela g3 compound and let the machine do the work, making sure to keep moving and checking progress. The haze disappears in no time leaving a new look. Great to have a few microfiber cloths too to wipe and check progress
