Can anyone help me with this problem. I have a 2000 E320 cdi which has developed the slipping gear problem.
Symptom: Started slipping and going into second gear i think. would reset when switched off and back on again. Got worse over a couple days. Now it will
hardly move. If you start it will engage into gear after 10 seconds but if you give it any acceleration it only revs and not passed 2000 rpm. No lights on.
Does not clunck into gear it is very smooth and always has been. No noises.
I had a friend read codes with the star reader.
P2500
P2502
P220A
History of car: Had transmission problem before i got it and had the electro plate, sensors, sleeve plug changed by JP Automotive over one year ago.
I confirmed this with them. I've had the car since December running great and so smooth.
What i've done to try and fix:
1. Checked transmission plug and found it clean free from ATF. Connector looked clean too. Expected this as it was changed just over a year ago.
2. Checked Transmission control module and found it full of ATF. Cleaned out and still same problem. Found capacitor blown so picked up another second hand unit but still same problem. Oil must have been sitting in their for over a year before new connector sleeve fitted..
3. Cleaned Transmission connector under bonnnet and looked clean now.
4. Checked MAF and confirmed okay.
5. Bought a ATF dip stick and have found too much transmission fluid but getting this double checked with a Mercedes dip stick. think this would not cause this problem though.
6. Battery voltage is fine.
Any help appreciated as i'm getting ready to pass this on to Mercedes and i know that will cost me a fortune..
What i'm wondering now:
1. Changing the Transmission control module? Do i need the codes cleared or would it work better straight away? Tried leaving the car overnight with the battery disconnected and holding down accelerator at position 1 etc.
2. Could this be the solenoid's on the electro plate?
3. Is it possible its the torque convector? I thought it would have thrown up another code..
4. Could my cable harness have that much oil trapped that would really cause it to slip gear?
Alex
P2500
P2502
P220A
Alex
