2001 E200 (w210) kompressor P200B Bank 2/5 error code
westy2005
Barnsley, South Yorkshire
Mercedes E300DT
Hi Guys,
looking for a bit of info for a neighbour, he was on the motorway the other day and the car lost most of its power and went into limp mode with the accompanying waring light on the dash - he has taken it to be checked and it it spat out P200B Bank 2/5 hot film mass air flow error code.
Upon doing a search it can relate to various things i.e faulty cats, MAF, o2 sensor.....
can anyone offer any advice on where to start, or would a clean of the MAF fix this??
He did state that it has been running a bit lumpy for a bit, but never acted like this previously
The car is a 2001 W210 E200 Kompressor Auto.
Many thanks in advance
Sam
stardiag first as it can be a lot of things.close to essex?
Check the engine wiring loom for oil contamination. Very common issue with those symptoms. A check with a Star and a live data check is in order.
Also there are some brass nozzles that block up and can cause engine breathing problems. The outcome can be a oil contaminated air mass sensor.
Sorry for delays, things cropped up and they came first - im not sure what system has been used to check the fault, is star diag a main dealer system??
sorry not near Essex, up in South Yorkshire
Where abouts is this section of the wiring loom???? I dont want to start pulling plugs out that are not relevant - any pictures would be ideal :-)
