Hi everyone
I've had an issue with my 2001 S210 E320 CDI where I am not getting the full power from the engine right away. Eventually it gets up to speed and from stationary moves away ok but there's no real "kick"!
Took it to my mechanic and he told me the motor controlling the air intake on the manifold is finito, seized.
Now my mechanic tells me that the flaps in the manifold were slightly stiff but he removed the motor and told me to try driving it without the motor, which I did. It drives faultlessly and the mechanic tells me that I can drive the car without the motor attached as ideally I should change the manifold as to not damage a replacement motor.
My question is: is it ok to drive without this motor? Will it cause any damage to the engine? Would you advise I replace the motor or the manifold & the motor?
What is the purpose of the motor? Part No. 613 150 04 94.
Thank you in advance.
