meeka
I just bought a 2001 Automatic Mercedes Cdi and I cannot get it to go above 3000rpm.
I have tried driving it only in D and the car always changes gear around 2000rpm even when I use Kickdown. The Kickdown switch seems to be Ok.
I have tried maually selecting gears and the car goes to 3000rpm in every gear and will not rise above this.
There is no black smoke. The engine is ruuning fine other than the rpm problem. A friend suggested changing the gear oil and filter and then think about checking other things. The car has done 120,000 miles.
Any one else had this problem or any ideas on the subject.
Thank-you,
meeka.
Thank-you,
meeka.
